I'm creating VG filters to enable fire rated doors and walls to with a solid hatch.
The filter works fine on walls but the doors will not display at hatch pattern at all
Any tips are appreciated.
thanks
Can't open your files now but I guess your door panel is set to invisible on plan/rcp and there is line work for plan/rcp presentation. You can either set the panel to visible for plan/rcp, or add a filled region for plan/rcp presentation, then it will show with solid hatch per your filter.
@Anonymous
The Cut Patterns which you are overriding in that filter applies to 3D elements in the Door family...
When the door family is modeled to display Symbolic lines instead of the 3D extrusions, you
