is there a way to "explode" a wall, in order to stretch certain layers? divide p
svalen
Message 1 of 14
svalen
Does Revit allow you to explode a wall so that layers all become detached? example, model gypsum stud wall, explode, then delete or stretch gypsum from one side? I know of the way to do this in edit type, base extensions etc, but was wondering if there is a type of explode tool for this? Divide parts?
Also, does Revit Lt have divide parts?
Replies (13)
Message 2 of 14
Redrunner92
This is what "Create Parts" is used for. After selecting a wall, use the button on your Modify tab:
Be sure "Show Parts" is selected in your view's Properties in any view in which you want to see a wall as parts rather than an integrated wall (after you have selected a wall and clicked Create Parts).
Message 3 of 14
hmunsell
if you are only stretching one layer edit the wall type and unlock that layer. i don't believe using the parts tool will not allow you to "Stretch" a wall layer, only divide it.
Howard Munsell
Message 4 of 14
Redrunner92
Good point. @svalen  To do what @hmunsell  said:
Message 5 of 14
hmunsell
Thanks... i have a screen cast for it, but i couldn't get it to attach.... 😞
here it is....
Howard Munsell
Message 6 of 14
Redrunner92
Dontcha hate it when attachments won't work? Haha. Wonderful, that's a good explanation.
Message 7 of 14
hmunsell
especially when your like "i Know that one....." and then your computer decides not to cooperate LOL
thanks, just happen to have a similar situation over the weekend that i made the screencast for. Actually for that one i ended up suggesting a Create Parts as a solution. it all depends on the situation....
Howard Munsell
Message 8 of 14
svalen
I see, thank you for this. Unfortunately, I'm using Revit LT, I don't beleive this option is avaiable...
Message 9 of 14
Redrunner92
Yeah and you're thinking "Please don't let that other person post before I do!" No worries though, you are an expert at this whereas I just have a bit more experience than many new users. I'll defer to you gladly.
Message 10 of 14
Redrunner92
Bummer! I see that now on the list I posted to you in another of your posts. Do you not have the Edit Wall Assembly option either? That isn't specified in that PDF list.
Message 11 of 14
svalen
Do you mean the standard "edit type"  option?
If not...where is Edit Wall Assembly?
Message 12 of 14
Redrunner92
Click into that Edit Type menu. The first row should be called Structure. Then click the Edit... button.
Message 13 of 14
svalen
Oh yes, I know of that method.  Thanks!
Message 14 of 14
preritk
Community Visitor
Community Visitor
Well the easiest way to do that would be-
1. Select the wall.
2. Create Parts.
3. Switch to 3d view and select each part and use displace elements.
4. Repeat the same process for each element.
