I'd like to extend a dormer cut to the bottom edge of the roof (which overhangs either side of the dormer)
The left hand dormer is showing a dormer cut
The right hand is showing a roof edge sketch cut around the dormer. But internally we don't have a conventional dormer square cut in the roof.
Trying to combine the two, revit doesn't like.
Any ideas?
Gelöst! Gehe zur Lösung
Gelöst von barthbradley. Gehe zur Lösung
I'm not clear on what you are asking, but if you can't there with the Dormer tool, what not just revise the Roof boundary to go around the Dormer Walls?
Great thanks! Hadn't realised I could select the roof as an Dormer cut edge.
