help a biggener "Lines cannot intersect each other. The highlighted lines curren
guys first of all I am a biggener in Revit , when I draw a shape and try to roof it a message appears sais " Lines cannot intersect each other. The highlighted lines currently intersect"
I understand the problem I searshed for a solution to trim the lines that are intersecting  with earh other but as I said I am a biggener so please can you give an advice about it
here is some pics of what is going on
hmunsell
lines can not "intersect" each other, they have to be closed shapes. you'll need to make 2 separate roofs  and join/cut them them
Howard Munsell
Redrunner92
In this case it looks like you will need to make two different roofs. A roof sketch (along with any sketch of an extrusion such as a floor, wall profile, etc.) must be one closed shape. This means, as your images show, lines cannot intersect each other except at corners. To make the octagonal roof shape, use the lines you have drawn as one roof, then make the roof around it (the larger, more rectilinear roof) a separate roof sketch.
An easy way to do this is to cut one of the roof shape's lines to your clipboard, then finish the first roof's sketch. Then start a new Roof sketch and paste-to-current-view the lines on your clipboard, then finish the sketch with the remaining lines needed.
thanks mate , I get it now
thank you my friend
Redrunner92
You are very welcome 🙂
hmunsell
not a problem....
Howard Munsell
