Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Is there a way to move an item diagonally, while using snaps?
David125
David125
If I just click and move an object, I can move up down, diagonally no problem. Using the MOVE command, then snapping to an end point of an item being moved, I'm forced to move along X or Y direction. Is there a way around this?
RDAOU
@David125 hi
I am not sure if this is what you are referring to but:
  1. when u start the command move..on the options bar there is a check box for "Constrain" which locks movement to certain plan/axis... Uncheck it.
  2. you chan also try to use shift key which temporarily enables/disables Constrain option
some elements may also require to you to check disjoin too
cheers
David125
Dadgumit! It had to be so simple, I hate it when that happens. Thanks, that was it.
