I applied override revit link inside VG (transparency and color). How can I transfer this to other views and files? Seems like VG overrides for Links don´t work well with View Template.
Override Revit links works well with View Template within one file. Once you go to another file with different links, the link names change, so the View Template needs to change as well.
How are you applying Vie templates to other views?
@RDAOU, Prop Dialog > View Template.
Even if the link has the same name, VG overrides for link, didn´t work. I believe has to do with Link ID.
In the same file I could apply View Template with just RVT Link Overrides checked and it works. Didn´t mess up all other view properties.
