Is there a way to delete a wall while saving the sweeps attached to the wall?
uffe0441
uffe0441
Hope someone can help, thanks.
uffe0441
I used sweeps for the whole facade and I get a ton of errors, maybe I should turn the sweeps into Mass instead.
I can't readily tell which parts are wall sweeps from you image but it appears curtain walls maybe a better approach.
