Is there a way to change " Stairs Tread Number FONT" ?
Corsten.Au
Advisor Advisor
Message 1 of 8
Corsten.Au
This is not critical but is there a way to change the "FONT" type of Tread Numbers... I have seens this same question being asked in Revit 2016, 2017, 2018 and I still can't see solution in 2019....This is not critical but is there a way to change the "FONT" type of Tread Numbers... I have seens this same question being asked in Revit 2016, 2017, 2018 and I still can't see solution in 2019....
Corsten
Building Designer
Replies (7)
Message 2 of 8
ennujozlagam
hello, just pick your staircase arrow > properties and edit type. see screenshot below. thanks
Message 3 of 8
Corsten.Au
That doesn't help changing the fonts of numbering.... it changes only Text " UP ' and " DOWN "
Corsten
Building Designer
Message 4 of 8
ennujozlagam
ooppps my bad, still on Idea Board? thanks
Message 5 of 8
I don't think you can change the font for the tread numbers tag. Only the size.
Message 6 of 8
ennujozlagam
you don't need to think it's already on idea board. read above please.
Message 7 of 8
LTanDHCGS
Then what font is the stair tread annotation?
Message 8 of 8
eleanna_panagoulia
No you cannot change the font. Only size, location and which treads to number (odd, even etc.)
