Is there a Lasso Selection Tool of some sort in this program or an add-on?
7 REPLIES 7
Message 1 of 8
951 Views, 7 Replies
What the title says...I am looking for a Revit version of AutoCAD'S lasso selection tool. Can someone please point em in the right direction? Also, if there isn't one out there can someone or the Dev's please create one? It is really asinine to manually select or tab select a hundred different object to move one wall 2 inches. Thank you.
Clell Hanson
7 REPLIES 7
Message 2 of 8
L.Maas
No there is no lasso selection tool.
Not sure what you are trying to do that you need to select so many items to move a wall. But probably there are other ways/tools (or combinations of tools) to get to where you need to be.
If you think the lasso selection tool would be  a useful addition to Revit (I personally never missed it) post your idea in the IDEAS section
Louis
Please mention Revit version, especially when uploading Revit files.
Message 3 of 8
in reply to: L.Maas
thank you.
Message 4 of 8
in reply to: L.Maas
And basically i am trying to move all of the walls throughout a building to fix a measurement error  at 2 different points not in the same axis. Also this is helpful if your client wants to remove 1 ft of space on 1 corner of a building but not touch a specific room or corridor. Thank you again for your response.
Message 5 of 8
Message 6 of 8
bill_gilliss
Try Polygon Select:
https://apps.autodesk.com/RVT/en/Detail/Index?id=4391834665520444603&appLang=en&os=Win64
Haven't tried it, but it sounds like what you want. Apparently a Window (not Crossing) polygon is used.
Message 7 of 8
RobDraw
Yeah, who would do that?
Rob
Message 8 of 8
bill_gilliss
in reply to: RobDraw
I use multiple windows, crossing or not, with SHIFT to keep adding to the selection set.
Forma Design Contest
