Invisible edges
3 REPLIES 3
634 Views, 3 Replies
Invisible edges
I a making a generic parametric family consisting of nested extrusions. How can I make the edges of joining faces invisible?
3 REPLIES 3
alan_eu
Hi @Anonymous
Edit your family and:
1. Use Modify / Join on everything (it must wit the same material and same alignment)
2. Use Linework (LW - shortcut) and select <invisible lines>. So click on every line you don't want to see. 🙂
Alan Araújo EESignature
Bee1ColabInstagram Alan Araújo RevitBee1ColabGrupo Whatsapp
Usuários do Autodesk Community:
  • Se a resposta resolveu o seu problema, clique em Aceitar como Solução! isso ajuda os outros usuários a encontrar rapidamente uma resposta e Curta se gostou 🙂
  • Manda um alô nas minhas redes sociais com +600 vídeos de de Revit/BIM, Templates e conteúdos semanais! Gratuitos! 🙂
in reply to: alan_eu
1. these are panels that need to parametrically behave differently - is is ok to "join" them?
2. I am in a family editor - is the LW supposed to work? it does not...
alan_eu
1. Yes, just do it 🙂
2. oops, my bad... we can´t use LW inside family, but still could use it inside the project on the same Families
