Guys, I have no clue how to control or make Rv to show the intersect lines. Attached you see machines with void intersect that leaves intersect lines B, but the extrusion A does not.
We have to show roof cricket as 2d lines for the same reason since Rv8. Must be a way, I m sure.
Solved by ToanDN. Go to Solution.
Did you have silhouette set to thicker line? This will cause the edge to have different lineweight.
Sketchy lines does have settings to increase and decrease but its detail/esthetic effect is random. Besides its sketchy 🙂 not supposed to be super detailed
Your description does not match the picture. I assume you want A, not B? If so you need to join/cut geometry to create the intersecting lines.
