Intersect lines
3 REPLIES 3
yes_and_no
254 Views, 3 Replies
Intersect lines
Guys, I have no clue how to control or make Rv to show the intersect lines. Attached you see machines with void intersect that leaves intersect lines B, but the extrusion A does not.
We have to show roof cricket as 2d lines for the same reason since Rv8. Must be a way, I m sure.
3 REPLIES 3
syman2000
in reply to: yes_and_no
Did you have silhouette set to thicker line? This will cause the edge to have different lineweight.
RDAOU
@yes_and_no
Sketchy lines does  have settings to increase and decrease but its detail/esthetic effect is random. Besides its sketchy 🙂 not supposed to be super detailed
Your description does not match the picture.  I assume you want A, not B?  If so you need to join/cut geometry to create the intersecting lines.
