Is there any trick to convert a Generic Model Adaptive Family to a simple Generic Model?
Thank you for the help.
@a.gerasheva what version of Revit are you using and can you share the file (adaptive component)
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
@a.gerasheva thanks for the files, can you also let me know why you need this conversion? Is this specific for a project use?
Viveka CD
Export the adaptive family to SAT then import the SAT in the other family.
@a.gerasheva wrote:Is this going to keep the parameters and their values?
Unfortunately, no.
