Intersecction T-shape
7 REPLIES 7
Message 1 of 8
Marielen_
406 Views, 7 Replies
I need to draw this intersection without the circled part in blue, that is, a T-shaped intersection. Until then it was designed with a metric profile family, when together the points form a unilateral corner.divisa canaleta1.PNG
7 REPLIES 7
Message 2 of 8
in reply to: Marielen_
Looks like you are trying to "blend" two concave shapes together.  Cut away the "excess" with a Void or two.   Post the file. Lets take a look at it.
Message 3 of 8
Marielen_
in reply to: barthbradley
I cannot post the project file, but I send the file with the specific part.
I didn't understand what VOID would be. Was it the molding of a void on the spot?
Message 4 of 8
Create In-Place Component Voids to cut away the overlapping geometry.  Are you familiar with how to do that?
BTW, are these Slab Edges suppose to be Cable Trays?  Just curious.
Message 5 of 8
Marielen_
if that's what I'm thinking, I modeled it on the spot as a vacuum extrusion and it didn't work. As you did? could you send me the file please? This structure is for rainwater drainage, but the concept you mentioned is similar.
Message 6 of 8
The two In-Place Component Voids are named "Generic Models bb1" and "Generic Models bb2". They are under the Generic Model Category in the Project Browser.
Good luck.
Message 7 of 8
2019 attached.
BTW: Void Sweeps were created using "Canaleta(bb)" Profile Family.
Message 8 of 8
Marielen_
I got it because of your help. Thank you!
Forma Design Contest
Technology Administrators
