Interior Elevation Labels
6 REPLIES 6
Dman21
2105 Views, 6 Replies
When I create an interior elevation in my floor plan, it shows both the "Detail #" and the "View Name" as shown in the attached screenshot "Wrong". Is there a way to turn off the "Detail #" and only show the "View Name" or vice versa?
I didn't have to do this in any previous projects, it would just automatically exclude the "View Name" from the interior elevation symbol. I included a screenshot "Correct" of an old project to show how I want the symbol to look. Thank you.
Diego
6 REPLIES 6
in reply to: Dman21
Sure there is. Create a TYPE with those labels turned off via a Visibility Parameter (e.g. On/Off type parameter associated to Label's Visibility property).
...You know, if I'm reading you right, that Type already exists in the OOTB Markers.
...like this:
Dman21
in reply to: barthbradley
Fixed, thanks so much!
Hi! I have a the same problem but I can't figure out where to go to Create a TYPE with those labels turned off via a Visibility Parameter.
Would it be possible to tell me where to go for those settings? Maybe some screen shots would be helpful.
Thank you!
Rux
hayleyLMGQX
in reply to: Dman21
I would love an answer to this question - please can you explain step by step how to create the type?
hayleyLMGQX
Please can you explain step by step how to do this?
jay_colcombe
in reply to: hayleyLMGQX
@hayleyLMGQX  @Anonymous
You have to delve down into the Family and see what Tags are used inside - as originally stated there are some already set up.
Select the Elevation Tag/Marker - At the End of the Elevation Tag line that reads 12mm circle click in it as 3 dots ... appear at the end - Click on this to see what is associated to this Elevation Tag
From here we can identify that this is the Family used in the Tag - From here you can select other Types of this Tag (Text arrangements and visibilities etc.) This is what the original solution recommended so a solution could be a couple of clicks away - try them all first to see what works for you!!
You can find this family in - Project Browser > Families > Annotation Symbols
If you still need to edit the Family and adjust or add in visibly Parameter's - Select in Family Tree > Right Click > Edit
In the Family, select what item you need to control - Then select Edit Type from the Properties Palette and you can see for Each Type the Visibility Parameters change to control what will be seen when each Type is used.
You do not want to override the existing so save it and reload back into the model as a new reference/family
Jay Colcombe
Autodesk Certified Instructor
