Insulation, Core Boundary and connection between floor and wall
g00396645
Message 1 of 14
g00396645
Hello
I am trying to replicate a project and so far i have the entire project replicated except for one aspect
There is a specific connection between the wall on the first floor and a Balcony which are not connecting properly?
Can  anyone advise how to get it right
What it should look like:
Notice how the insulation on the floor to the left connects to the wall
What it currently looks like:
I have palyed with the core boundaries and layers in many different configurations, joining , changing join order etc and i cannot get it right
Please let me know if anyone can help 🙂
Replies (13)
Message 2 of 14
Like this?
Message 3 of 14
g00396645
Hello
Thanks for the reply
See attached, i included the wall and the Balcony on the left and floor on the right
Message 4 of 14
g00396645
Yes, that is near exactly what i am trying to accomplish
Message 5 of 14
g00396645
This is exactly what I am looking to do, is there an extra step to join it like this? Or will it join automatically depending on the structure make up
Message 6 of 14
No special joining, just attach the wall base to the floors, or lower the wall base to the floor insulation layer and join geometry.  I did need to revise your floor and wall assembly layers.  See your revised file.
Message 7 of 14
colmDG4AB
Technically though what supports that left hand side masonry leaf? You can't just leave it sitting directly on insulation. Unless it's some sort of super strong compressive insulation I am not aware of.
Message 8 of 14
g00396645
Thank you very much! This is perfect
Message 9 of 14
g00396645
Technically yes, however, as this is more a visual project. we are required to make an exact copy of the given drawing for Revit proficiency
Message 10 of 14
I have to agree.  If it was me who detailed it would be like one of these.
Message 11 of 14
g00396645
For curiosity, how did you do the second image? Where the concret slab runs under the insulation and connects to the other floor?
Message 12 of 14
Overlap them like below, join geometry and switch join order.
Message 13 of 14
g00396645
Perfect, thank you so much!
Message 14 of 14
colmDG4AB
Just overlap the 2 floors. Make sure they are the same material and hit join geometry.
