Wall Type Embedded Sweep Vis Control
My question is: when Autodesk will finally address this issue; I saw on 2007 forums the same issue and is not resolved but it is quite important. It's been 25 years and nothing is done.
There is an option to integrate sweep to wall type using the wall section and adding the sweep, but there is no way to control data about that sweep, so for example I would like to have an option to assign category to that sweep so I can turn that sweep off in plan view. there is only option to set profile, material and offsets but there is no way to switch that sweep off in plan view.
I know I can use sweep tool to get the same thing done but it take much more time especially in large floor layouts and besides Revit is all about automation. So everything is good to the moment when I have to dimension the walls and it is pain in the butt and besides the wall graphic representation itself in 1/4" scale is super congested. why not to fix a simple problem, just add one additional column in sweeps window which is category and be able to use drop down list of that, for example if I create subcat for wall "base" it will pop up in that drop down category menu, once I have it assigned I'll be able to switch on or off that
