Installation of Revit 2017 Content Libraries
IMCornish
Message 1 of 63
IMCornish
I have read solutions for the installation of 2015 and 2016 Revit Content libraries which apparently also apply to 2017 but since the first step is to find 'Autodesk Revit Content Libraries 2017' in your Control Panel's 'Programs and Features' and it does not exist I would ask how do you actually install the Revit 2017 Content?
See snipit below of my 'Programs and Features':
Revit 2017 is installed, as can be seen, but no Content Library!
Any ideas
Andrew Robertson
Chartered Architect
Robertson Partnership
Truro. UK
Replies (62)
Message 41 of 63
kmiros
How about you post a link where people can download a default library , is that a something hard to do for Autodesk Monopoly corporation.
Speaking of since you charge 5K for this application with bunch of glitches which should be flawless for that price if you asked me. Can you and your Gearheads in Autodesk make conduit and cable tray more custom so you can asign material as well as jepg labels on duct and piping system it will help a lot BIM industry especially semiconductor facility's such as Globalfundries to have accurate 3D model of existing condition of the FAB 8 .
Thanks Autodesk for trying hopefully you can get it done with the next service pack , I'm looking forward to your contribution to architect and engineering socity it will make life eaiser on our end when we do design utilizing your application Such as Revit and Navisworks , speaking of your Navisworks shrinking view crop box could work like in Revit instead us playing with move and scale commend waist of time when I could just select the grips arrow heads and shrink the object in 3D space to the portion that i want to show .
Sincerely
Krzysztof Miros
VDC BIM Lead / BIM Coordinator
Message 42 of 63
I have the exact problem with revit 2018, is there any solution??
Message 43 of 63
kmiros
There is very simple solution to that , waiting on Autodesk get their act together it takes for ever .
1. Uninstall your Revit.
2. Delete All of the  Autodesk folders from :
a.) C:\Program File\Autodesk
b.) C:\Program File86\Autodesk
c.) C:\Program Data
d.)C:\Users\yourname\AppData Folder
3. Typr Run.exe Regedit (as admin) find all of the Autodesk folders ,reg key's within that Microsoft mess.
4. Final set install yourself fresh copy of Autodesk Revit
5. Be happy again that you can do finly do some design , instead of fixing broke ass application that cost over 5k and hardly work , Its frouad and scam charge type of price all of the engineering firm's for broke ass application that a design like ****.
How come Solidworks , Cinema 4D , Zbrush, Modo 10.2, Houdini, ArchiCAD and some other application that are way much cheaper never get stuck on  " Not responding " freezing issue at least they have their act together , autodesk its monopoly all they care about get money less of improving their 1990's 3ds Max that hardly change other than additional tools their GUI is garbage compare to Modo that has way smoother transition and flexibility , but who cares right according to autodesk those corporation going to buy Lic anyway , cause by end of the day we all got get the job done.
So it is what it is mate
Come see us on GFXpeers we got a lot good stuff for you sponsored by X-Force
kmiros
Message 44 of 63
Dear Tony Michniewicz
Could you attach the files (masterxml) for Revit 2018?
Regards.
Message 45 of 63
Message 46 of 63
Thanks men...!!! Appreciate.
Message 47 of 63
Your suggestion, wasted approx. 8GB of bandwidth, 5-6 hours almost, but didn't help.
Message 48 of 63
kmiros
You must been doing something wrong ,it takes me uninstalling old Revit and cleaning folder as well as  registry folders with about 25 min max .
After that i run new version of Revit and everything works just fine .
Try one more time use Revo Uninstaller or Iobit Uninstaller
I hope this works for you , unless your pc is in rally bad shape .
Sincerely
kmiros
Message 49 of 63
Do we have a support download section where we can just download the content family files? I just want to load past Revit families into Revit 217. It seems that Autodesk is going corporate and not remaining helpful. Might anyone else on here have the Family Folders for previous versions of Revit? Going as far back as 2012? Or maybe tell me where to go for the old files from www.seek.autodest.com before it changed to a brand name sales location? Please let me know.
w0547806@apps.losrios.edu
Message 50 of 63
jeffinitely
I still cannot get the Revit 2017 Content Libraries to work on my computer.  My product is not working as it should.  My software is incomplete.  I have been led to believe that by spending X-amount of dollars, this software will work but it does not work as advertised.
I've updated/checked for updates/installed/uninstalled/reinstalled/downloaded/stood on my head and it still doesn't work.
How many more days do I need to sift through these forums?  Has anyone actually had any luck with this?
Message 51 of 63
where is local folder?
Message 52 of 63
RobDraw
Maybe you did something wrong.
Rob
Message 53 of 63
1. Install Revit 2017
2. Download 'RVT 2017' by search or from the link https://comgraph.autodesk360.com/g/shares/
3. Copy  or Replace ' C:\ProgramData\Autodesk\rvt 2017'   folder
Simple Smiley Happy "I am Sure it will Work"
Message 54 of 63
Revit Error will clicking Resource list in UIE Of revit, i could not open Help function, & cannot load materials also.
Message 55 of 63
I'm having this same problem but in 2018.  I've tried the different help files but they are all setup for 2017.  Any help would be great.
Message 56 of 63
Tony_Michniewicz
Message 57 of 63
kmiros
Thanks Tony for sharing these links with us , at least one decent Autodesk employee kudos goes to you we need more people like you.
Message 58 of 63
thomas.ryan001
Community Visitor
Community Visitor
Finally, an actual solution.  Thank you so much.
Message 59 of 63
I have downloaded and extracted this to the correct folder three times now and NOTHING is there!! What am I doing wrong? I have been trying get Revit 2019 to work for days....help
Message 60 of 63
RobDraw
Hard to see what you are doing wrong. The magic portal to see a history of what you've done is broken. Most people can download to appropriate content from the links above.
Rob
