Revit 2017 Installation Fails
MartynDuncan
MartynDuncan
Had this with 2016 version of Revit LT but always too busy to spend time to sort it out. Has happened again with the upgrade to 2017.
Contents of the log below - message is that "Installation Complete - some products failed to install" - Pretty much everything failed to install!!
2016/5/4:08:57:54 Martyn MARTYN-PC === Setup started on MARTYN-PC by Martyn ===
2016/5/4:08:57:54 Martyn MARTYN-PC Path_Length: 155
2016/5/4:08:57:54 Martyn MARTYN-PC Current Directory C:\Autodesk\Revit_LT_2017_G1_Win_64bit_wi_en-US
2016/5/4:08:57:54 Martyn MARTYN-PC Launch
2016/5/4:08:57:54 Martyn MARTYN-PC CommandLine /PK 834I1 /SN 559-88550746 /akamai /sid a1b3A0000093JRcQAM /skipEULA /skipPI /url "http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/Revit_LT_2017_G1_Win_64bit_wi_en-US_Setup....
2016/5/4:08:57:54 Martyn MARTYN-PC Current Directory C:\Users\Martyn\AppData\Local\Temp\_AI85D2.tmp
2016/5/4:08:58:27 Martyn MARTYN-PC === Setup ended ===
2016/5/4:08:57:55 Martyn MARTYN-PC Download Play SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/SET...
2016/5/4:08:57:55 Martyn MARTYN-PC Download Complete SETUPMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/SET...
2016/5/4:08:57:56 Martyn MARTYN-PC Download Play SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/SET...
2016/5/4:08:58:27 Martyn MARTYN-PC Download Complete SETUP_CONFIG http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/SET...
2016/5/4:08:58:27 Martyn MARTYN-PC Install CustomCallback Info Invoking custom callback for details: [SETUP] CB_FUNC=CustomCallbackRevitOSVersionCheck CB_SOURCE=C:\Users\Martyn\AppData\Local\Temp\_AI85D2.tmp\Setup\RevitSetup.dll
2016/5/4:08:58:27 Martyn MARTYN-PC Install CustomCallback Info Custom callback response: Status=0 SUCCECSS Title= Message= URLTitle= URLLink=
2016/5/4:08:58:27 Martyn MARTYN-PC PageOpen LaunchDialog
2016/5/4:08:58:31 Martyn MARTYN-PC Install CustomCallback Info Invoking custom callback for details: [RCL] CB_FUNC=CustomCallbackRevitContentWarning CB_SOURCE=C:\Users\Martyn\AppData\Local\Temp\_AI85D2.tmp\Setup\RevitSetup.dll
2016/5/4:08:58:31 Martyn MARTYN-PC Install CustomCallback Info Custom callback response: Status=1 INFO Title= Message=Deselecting the content installation will affect critical settings in Autodesk® Revit® LT 2017. URLTitle= URLLink=
2016/5/4:08:58:33 Martyn MARTYN-PC PageOpen LicenseDialog
2016/5/4:08:58:33 Martyn MARTYN-PC PageOpen ProductInfoDialog
2016/5/4:08:58:33 Martyn MARTYN-PC PageOpen ProductSelectionDialog2
2016/5/4:08:58:39 Martyn MARTYN-PC PageOpen FullProgressDialog
2016/5/4:08:58:40 Martyn MARTYN-PC Download Play STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/STA...
2016/5/4:08:58:40 Martyn MARTYN-PC Download Complete STARTMARKER http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/STA...
2016/5/4:08:58:40 Martyn MARTYN-PC Download Play VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:42 Martyn MARTYN-PC Download Complete VCREDIST2012X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:43 Martyn MARTYN-PC Installing Microsoft Visual C++ 2012 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit LT 2017\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2016/5/4:08:58:43 Martyn MARTYN-PC Install Microsoft Visual C++ 2012 Redistributable (x86) Failed Failure is ignored, Result=1603
2016/5/4:08:58:43 Martyn MARTYN-PC Download Play VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:46 Martyn MARTYN-PC Download Complete VCREDIST2012X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:46 Martyn MARTYN-PC Installing Microsoft Visual C++ 2012 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit LT 2017\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2016/5/4:08:58:46 Martyn MARTYN-PC Install Microsoft Visual C++ 2012 Redistributable (x64) Failed Failure is ignored, Result=1603
2016/5/4:08:58:46 Martyn MARTYN-PC Download Play VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:50 Martyn MARTYN-PC Download Complete VCREDIST2015X86 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:50 Martyn MARTYN-PC Installing Microsoft Visual C++ 2015 Redistributable (x86): "C:\Autodesk\WI\Autodesk Revit LT 2017\3rdParty\x86\VCRedist\2015\vcredist_x86.exe" /install /quiet /norestart /log C:\Users\Martyn\AppData\Local\Temp\vcredist_x86_2015.log
2016/5/4:08:58:50 Martyn MARTYN-PC Install Microsoft Visual C++ 2015 Redistributable (x86) Succeeded
2016/5/4:08:58:51 Martyn MARTYN-PC Download Play VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:54 Martyn MARTYN-PC Download Complete VCREDIST2015X64 http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/VCR...
2016/5/4:08:58:54 Martyn MARTYN-PC Installing Microsoft Visual C++ 2015 Redistributable (x64): "C:\Autodesk\WI\Autodesk Revit LT 2017\3rdParty\x64\VCRedist\2015\vcredist_x64.exe" /install /quiet /norestart /log C:\Users\Martyn\AppData\Local\Temp\vcredist_x64_2015.log
2016/5/4:08:58:55 Martyn MARTYN-PC Install Microsoft Visual C++ 2015 Redistributable (x64) Succeeded
2016/5/4:08:58:55 Martyn MARTYN-PC Download Play RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/RCL...
2016/5/4:08:58:58 Martyn MARTYN-PC Download Complete RCL http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/RCL...
2016/5/4:08:58:58 Martyn MARTYN-PC Installing Autodesk® Revit® LT Content Libraries 2017:  TRANSFORMS=":en-us.mst;C:\Users\Martyn\AppData\Local\Temp\_AI85D2.tmp\x64\RCL\RCL-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit LT 2017" INSTALLDIR="C:\Program Files\Autodesk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/5/4:08:59:03 Martyn MARTYN-PC Install Autodesk® Revit® LT Content Libraries 2017 Succeeded
2016/5/4:08:59:03 Martyn MARTYN-PC Download Play CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/CLM...
2016/5/4:08:59:04 Martyn MARTYN-PC Download Complete CLM http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/CLM...
2016/5/4:08:59:04 Martyn MARTYN-PC Installing Autodesk Licensing Manager:   TRANSFORMS="C:\Users\Martyn\AppData\Local\Temp\_AI85D2.tmp\x64\CLM\CLIC_x64_Release-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk Revit LT 2017" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2016/5/4:08:59:12 Martyn MARTYN-PC Install Autodesk Licensing Manager Succeeded
2016/5/4:08:59:12 Martyn MARTYN-PC Download Play RLT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/RLT...
Above appears to be all OK and this is where it goes wrong:-
2016/5/4:09:02:50 Martyn MARTYN-PC Download Aborted RLT http://efulfillment.autodesk.com/NET17SWDLD/2017/RVTLT/WI/{4F6A2D57-22E5-4FC1-9509-B25EA9CD86BE}/RLT...
2016/5/4:09:02:50 Martyn MARTYN-PC Install Autodesk® Revit® LT 2017 Failed Download Failed, Installation aborted, Result=1603
2016/5/4:09:02:59 Martyn MARTYN-PC Rollback Autodesk Licensing Manager Succeeded
2016/5/4:09:03:04 Martyn MARTYN-PC Rollback Autodesk® Revit® LT Content Libraries 2017 Succeeded
2016/5/4:09:03:04 Martyn MARTYN-PC Rollback Microsoft Visual C++ 2015 Redistributable (x64) Failed Failure is ignored, Result=1619
2016/5/4:09:03:04 Martyn MARTYN-PC Rollback Microsoft Visual C++ 2015 Redistributable (x86) Failed Failure is ignored, Result=1619
Without trawling the massive amounts of forum suggestions, I thought that I would add it as a new thread. Any help would be gratefully received.
ennujozlagam
hello, have you try to switch off all your anti virus program and firewall before downloading and installation. thanks
MartynDuncan
Switching the AV and FW off temporarily worked - thanks for the info.
