Download Revit 2017 and move the image to a server to install clients
1 REPLY 1
Cadenas
274 Views, 1 Reply
Cadenas
just download Revit 2017 and the "InstallNow" downloader works fine. The downloaded image seems to be on disc in c:\autodesk\.. but i can´t move this files to the server and install the real client there. It always comes the message that there is a communication error when starting setup.exe in this folder. Also the option "download browser" is not available for Revit 2017, for older version it is.
Please assist .. how to move the download to a server location and install multiple clients from there
thank you
  Markus
thank you
  Markus
1 REPLY 1
Cadenas
in reply to: Cadenas
Cadenas
After playing around the solution is to select the multi language packet .. for this the download option is available and not only the install option
