- Mute
- Permalink
- Report
I am trying to change the line type of only one material in a wall. We want to represent our 1-hr rated fire wall(2 layers of cmu blocks and fire stop material) with different line types for just the 1-hr material. For example, (Solid lines for the CMU blocks), but (Center lines for the 1-hr).
If you use filters even with and/or conditions it still changes the line types for the whole wall. Override graphics in view does the same thing by changing the whole wall not just one material. If you do common lines then all walls with multiple materials will change. You can change the line type by selecting the lines representing the edges of the 1-hr material, but you have to do that in every view, because they don't carry over to the section views.
I created a new hatch pattern that looks like the line type we want in a .pat file, but you have to make a horizontal and vertical pattern depending on the orientation of the wall. From all the posts, forums, YouTube videos it doesn't seem possible, because walls are system families. We have 2018 and I have tried it on my 2019 version, but no luck. We are upgrading to Revit 2020 soon. Does anyone know if this is possible with 2018, 2019, or 2020?
In AutoCAD I would just write a lisp program and be finished, but I do not know enough C# to know whether it is possible that way in Revit. Any Help would be much appreciated.
The Photo with all black lines is how we'd like it to look, but the photo with the red lines is all we can do.
