Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Increasing the size of the minimized woindow
Hello everyone,
Can I increase the size of the the windows label when I have minimized it? Yhe ones that show at the bottom of this picture.
Best regards
You want them wider?  How about cascading instead of tiling?
what is cascading? do not know that word
Cascade.pngCascade.png.
Thats on the manage tab?
best regards
Avaris.
Before Revit 2019 it was on the view tab. But you can also press the shortcut WC.
EDIT: Tried it but it does not work. Couldn't find an option to make it wider either. I assume it is not possible. I recommend maximizing all of them and use the 'switch windows' to read the labels.
Since 2019 your are not able to minimize them; views are then tabbed or in tiles.
@Anonymous: Are you saying you don't have Cascade on the View Tab? Press WC.
...Switch Windows is a good one too.  I use that one all the time.  Located on the Quick Access Toolbar. Not a big fan of WC or WT.
