Inaccurate calculated volume with In-Place-Mass
- Mute
- Permalink
- Report
Hey, I have discovered a big issue with an inaccuracy with the calculated volume in the In-Place-Mass tool.
First I imported a solid form from Rhinoceros in the In-Place-Mass tool. Revit wasn't able to calcute the volume because the shape was to complex for Revit. Then I added a simple solid form, being still in the same In-Place-Mass process. This time Revit calculated the volume of the simple solid form. Then I edited the Mass again an deleted the simple solid form but after finishing it the calculated volume was the same as before. So now the false volume is clinging on my imported solid form. This doesn't happen when you do the same with two simple solid forms, I've already tried that.
So how can I avoid such inaccuracys? The only way to fix it that I found was to delete the whole mass an do it again.
complex solid without volume
solid with block and volume of block
solid after deleting block
