Importing PBR materials into REVIT
1 REPLY 1
KKProssick
973 Views, 1 Reply
Hello Community, quick question.
I have downloaded some PBR material files from CGAXIS.com and I was wondering if there is an easy way to import them into REVIT?
Thanks, Keith
Tags (3)
1 REPLY 1
perry.swoboda
in reply to: KKProssick
I am looking for a quick way too.  Best information I have so far is that you need to duplicate an existing PBR material that is similar (uses the same shader) and then add in specific files from your PBR material.
Here is a tutorial I found on using Substance3D PBR materials in Revit.
https://www.toolfarm.com/tutorial/how-to-use-substance-materials-in-revit-2019/
