Export outer shell Revit model. How?
9 ANTWORTEN 9
Nachricht 1 von 10
krittapon
1476 Aufrufe, 9 Antworten
Hi, I can not figure out to bring lighter revit model to google earth for a week and is this possible to export only outer shell Revit model? Or another possible way to export model to google earth with lower detail.
(massing with outer picture of shell or some thing?)
Thanks in advance.
9 ANTWORTEN 9
Nachricht 2 von 10
ennujozlagam
als Antwort auf: krittapon
you can try to copy the outer shell from 3D view then paste it into a new file. thanks
Nachricht 3 von 10
Which method do you bring the Revit model into Google Earth?
Nachricht 4 von 10
Thanks in advance.
What makes you think the Model is too heavy?
Nachricht 5 von 10
krittapon
als Antwort auf: ennujozlagam
Thanks for answer.I used this method already and it seem doesn't what i want.
Nachricht 6 von 10
krittapon
als Antwort auf: ToanDN
Export all kind to Navis and use "Google Earth KML" in Output tab.
Nachricht 7 von 10
krittapon
als Antwort auf: barthbradley
Thanks in advance.
Too much laging when import KML file to Google Earth.
I can't orbit or pan my screen. If delete import file every thing is work properly.
Nachricht 8 von 10
ennujozlagam
have you tried to bind instead of deleting import? and what is the outcome? thanks
Nachricht 9 von 10
krittapon
Did you mean bind instead in google earth?
Nachricht 10 von 10
Hide everything in the view except for what you need to see in Google Earth and set the Navisworks export to Current View.  How to hide effectively?  Turn off Categories under VG, put elements in different worksets and close the worksets, etc...
