Importing Family Problem
jochia13
jochia13
I am trying to import a kitchen families into rivet and I keep get the error below in the pic. What could possibly be the problem?
RmsMali
Your Revit Project already has shared parameters "Nominal Width" , "Weight Net",  "Nominal Height".. All these parameters were initially added to your Project with type as "Numbers".. Now, you are trying to add the same items with "Text" type..
Possible Solution: Delete the shared parameters "Nominal Width" , "Weight Net",  "Nominal Height" inside your Project.. Then try to reload the families.. (If you already have set many data with those parameters, then you might lose them)
