Hello everyone,
My problem is that when i import a CAD file into Revit, the CAD file gets distorted.
Did anyone faced this problem can help me ?
Would you be able to attach the CAD file?
CAD file is aligned ,the problem when i insert it into revit ,This is the angle between wall and CAD grids .
When the above is the first thing to pop up when trying to link/import a cad then it is either of 2 things
Open the cad file and check the following XREF at 0,0,0
The CAD you sent is the file I captured the screenshots from...download and open it then zoom extent. you will see that there are elements way more than 20miles apart
I've look at your file and it is beyond your origin point. This is why you have line jittering. Also for angle, Revit will always look for shortest angle. In CAD you can control what you want as angle but it makes no sense since builder will want the closest angle possible.
