Announcements
Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
IMPORTING AND SHOWING ONLY IN SELECTED VIEW
s3687147
s3687147
ITOPO.JPGTOPO.JPG have imported the topographic model as a revit file in 3d view , is there an option that says show only in 3d view?
Basically im trying to avoid to go in every single drawing to hide it.
Cheers
Michael
ennujozlagam
You can try this create a View Template and go to view visibility, uncheck from model categories and apply to views you don't want to see your topography. Thanks
Several ways:
- put it in a workset default to not visible and turn it on where you need it
- put it in a secondary design option
- put it in a future phase and set only the 3d view to capture that phase
- use view templates
s3687147
thanks for your response.
i got up to here (see attached image)  and i cant find view visibility.
hmm...that's a tough one. I wonder if V/G overrides for imported geometry might be under "V/G Overrides Import".   Yeah; that might be a bit of a stretch.  Never mind.
ennujozlagam
ease see attached. thanks
s3687147
Life changer! thanks soooo much!
Cheers
Michael
