IMPORTING AND SHOWING ONLY IN SELECTED VIEW
6 REPLIES 6
s3687147
630 Views, 6 Replies
ITOPO.JPG have imported the topographic model as a revit file in 3d view , is there an option that says show only in 3d view?
Basically im trying to avoid to go in every single drawing to hide it.
Cheers
Michael
6 REPLIES 6
ennujozlagam
in reply to: s3687147
You can try this create a View Template and go to view visibility, uncheck from model categories and apply to views you don't want to see your topography. Thanks
Several ways:
- put it in a workset default to not visible and turn it on where you need it
- put it in a secondary design option
- put it in a future phase and set only the 3d view to capture that phase
- use view templates
s3687147
in reply to: ennujozlagam
thanks for your response.
i got up to here (see attached image)  and i cant find view visibility.
hmm...that's a tough one. I wonder if V/G overrides for imported geometry might be under "V/G Overrides Import".   Yeah; that might be a bit of a stretch.  Never mind.
ennujozlagam
ease see attached. thanks
s3687147
Life changer! thanks soooo much!
Cheers
Michael
