I have imported the topographic model as a revit file in 3d view , is there an option that says show only in 3d view?
Basically im trying to avoid to go in every single drawing to hide it.
Cheers
Michael
Solved by ennujozlagam. Go to Solution.
You can try this create a View Template and go to view visibility, uncheck from model categories and apply to views you don't want to see your topography. Thanks
hmm...that's a tough one. I wonder if V/G overrides for imported geometry might be under "V/G Overrides Import". Yeah; that might be a bit of a stretch. Never mind.
ease see attached. thanks
