Imported IFC in wrong place inside Revit (correct in Solibri)
Marcus.Isacsson
Message 1 of 20
Marcus.Isacsson
Hi fellas!
We have a problem with importing IFC files in one of our current projects.
The files end up in the right place when imported into Solibri, but in Revit it doesn't match the rest correctly.
I guess that it could be some problems with our Project Base Point and the Revit startup location (origin) being in different places? How should we fix this?
Thanks in advance!
Replies (19)
Message 2 of 20
Viveka_CD
@Marcus.Isacsson
Can you share the files, Revit version and journals to test on our end?
Message 3 of 20
Marcus.Isacsson
@Viveka_CD  Sure, I'll send a link a to you as a message here at the forums.
Where do I find the journals?
Message 4 of 20
Why would you expect the IFC to land differently on placement in Revit?  Was the IFC originally exported from Revit  with Shared Coordinate System Components to IFC Site?   What is the genesis of the IFC?
Message 5 of 20
Viveka_CD
@Marcus.Isacsson
journals can be found here:
These files are stored in the following folder: %LOCALAPPDATA%\Autodesk\Revit\<Product name and release>\Journals.
Looking forward to your files.
Message 6 of 20
Marcus.Isacsson
We don't expect them to land differently, this is the weird part.
If I import our IFC-model, MEP and construction it all lines up in Solibri. But in Revit it doesn't.
We've used two shared coordinate systems, one for local coordinates and one for geographic coordinates.
Message 7 of 20
martin.rosenvingeQ9K3U
Is there a good solution to this? We have this same problem often in my company. Would appreciate some good feedback on this.
Message 8 of 20
If anybody from Auodesk, please give solution here? This is a big problem and always create mess whenever model is updated. Kindly help.
Message 9 of 20
Viveka_CD
Hi @Anonymous
Please log a support request with relevant files/ screenshots and one of our specialists will get in touch with you.
Message 10 of 20
Has a solution here been found?
Message 11 of 20
maxx.blake
We have the same problem, and I think it has to do with the Revit Internal Origin...
We our Engineers have modeled the building at a different location relative to the Revit Internal Origin, so when we export our IFCs by Shared Coordinates, our models are in the same position in Solibri but when we link their IFC file into our Revit model (or they, ours) then the IFC comes in at the WRONG place.
What is the solution to this? How can we "Link IFC by Shared Coordinates"???
Message 12 of 20
maxx.blake
Have you found a solution to this? We have the same problem in our office...
IFCs are in the correct position in Solibri - the wrong position in Revit.
When we like the Native Revit Files by Shared Coordinates, they are in the correct position.
However, our two collaborators have different Internal Origins, which is causing the discrepancy. I.e. when Revit links an IFC it can only link by Origin to Origin... what a disaster...
Message 13 of 20
joakim
Observer
Observer
We have the same problem. Is there any solution to the ifc-import?
Message 14 of 20
Marcus.Isacsson
Hi everyone! Our solution was by using attached Dynamo script.
The script updates the selected IFC-file to using the shared coordinates. Or at least I think so, I'm not 100% sure to be honest. Feel free to try it out!
Message 15 of 20
martijn_pater
Perhaps load the IFC into a seperate revit project, move in position and link the rvt...? Apparently that's the method with point clouds anyway (non-related)...
Message 16 of 20
This is kind a bug with Navisworks which disorient sometimes ifc from revit to wrong coordinates. Please uncheck below highlighted in File -->Option, uncheck Revit IFC
Message 17 of 20
koert.vynckier
When you Link an IFC it's always Internal Origin to Internal Origin.
You can export to IFC with a different Origin (Survey Point, Project Base Point, etc.) , but Link is still strictly Internal Origin to Internal Origin.
There's an idea to vote for more options when Linking IFC, but not implemented so far. You know what to do...
https://forums.autodesk.com/t5/revit-ideas/ifc-import-using-project-base-point-not-revit-origin/idi-...
Kudos to @Meelis123 for summing it up nicely
While linking IFC file we want to be able to choose between these options:
  1. IFC local coordinates to Internal Origin
  2. IFC local coordinates to Project Base Point
  3. IFC local coordinates to Survey Point
  4. IFC ifcSite coordinates to Internal Origin
  5. IFC ifcSite coordinates to Project Base Point
  6. IFC ifcSite coordinates to Survey Point
  7. Center to Center could be handy too
Message 18 of 20
Marcus.Isacsson
Voted!
Message 19 of 20
a.bejenaru
In my case the Level Building Story parameter was not checked.
Once I've checked the parameter the models locations were matching perfectly
Message 20 of 20
KIMRAMFI
Only Autodesk dares to ask you to vote something what is normal to other softwares.
