I've recently been involved in some tests linking IFC files created in Archicad into a Revit project. There is a major issue with this as the linked IFC file is located using Revit's internal origin and not the project base point.
Revit has been specifically set up to work using the survey point and project base point and for successful collaboration it needs to be able to link IFC files in the correct geographical location. Currently the test model I'm linking is so far from the origin the geometry is completely corrupt and unusable.
Cheers
K.
