Imported CAD Solid Hatch vanishes in Textures Visual Style when Transparency is >0%
omb_tsargent
omb_tsargent
I am using Revit 2024
I have a planting family with a CAD file inserted into it.
When I place the planting family in my project it looks great.
In a view with the Textures Visual Style applied it looks great too.
UNTIL I increase the transparency of the Planting category (or by object) above 0%.
When I set Planting transparency to 40% the Solid Hatch for the trees vanishes completely.
Same at 1%.
I would expect the material applied to the Object Style to not vanish, but to display the Material's Graphic's Shading Color, but with a 50% transparency.
  • Adding an Image to the Appearance asset for the material applied to the hatches also doesn't solve the problem.
  • Modifying Object Styles doesn't solve the problem.
  • Modifying Materials in Object styles doesn't solve the problem.
  • The issue only exists in the Textures Visual Style.
  • When I select the planting family, it only shows the linework, the fill doesn't get selected and turned solid blue.
  • Changing from Planting family to Generic Model family doesn't solve the problem.
If I import the CAD file directly into the project, I can adjust transparency as I would normally expect.
Am I missing a step in setting up my planting family? Or is it a bug that Nested CAD in a family will stop displaying filled regions in the Textures Visual Style when any transparency is applied?
EricaConcolino_Symetri
Care to share the family and CAD file, to help troubleshoot?  This is hard to diagnose without.
RDAOU
@omb_tsargent
You stated, "Solid hatch disappears when transparency is applied." This implies that it's a 2D CAD hatch, i.e., transparency won't work in such a case.
What type of object is this CAD import? Is it a 2D hatch, a mesh, a surface, or a solid?
omb_tsargent
Attached are the CAD file and the family.
In CAD, it is a 2D Hatch. The hatch is a "Solid" hatch eg. continuous fill, no pattern.
Importing just the CAD into a project permits transparency.
Importing the family with the nested CAD does not permit transparency.
This doesn't feel intended.
omb_tsargent
@EricaConcolino_Symetri
@RDAOU
See above post for responses.
