Revit Hatch Pattern
Revit Hatch Pattern
sthakkar3
Revit Hatch Pattern
sthakkar3
Hey all,
I am trying to write my own custom hatch pattern, but having a really hard time......... Here is the pattern I am trying to make:
Mosaic Accent Tile
Manufacturer: Tilebar, this is the product: https://www.tilebar.com/cul-de-sac-athens-gray-and-asian-statuary-tile.html
Any help/suggestions would be really helpful! Thank you!
David_W_Koch
Welcome to the community!
What are you trying to show in the fill pattern?  Each individual tile?  (Including the small squares??)  Or would lines showing the boundaries between the small squares and larger "marble" areas be sufficient?  Do you have the dimensions of the pattern?
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
sthakkar3
Hi David!
The only information the manufacturer has is that 1 tile is 11.56 x 11.75" and this is pattern on that individual tile:
I just trying to keep it simple with just single lines, no thickness of anything anywhere. As long as the overall tile size correct, the pattern can match but doesn't have to be exact.
Mike.FORM
Here is one that is 11.75 in both directions.
Mike.FORM
Also here is a Visual Reference for understanding the numbers and how they function in a pattern.
sthakkar3
Wow, thank you so much, this is really helpful!
