Problem reinstalling revit
emst0004
emst0004
Hello.
I had back in 2022 the Revit software, i tried to download 2025 but it says revit was already installed.
Now i deleted every folder on my computer also deleted in the "regedit".
Now i tried to install 2026 and the installer wont even open when i click on it. "Autodesk_Revit_2026_0_1_ML_setup_webinstall"
The 2025 wont open either, dont know what to do now.
Best Regards.
HVAC-Novice
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-Complete-a-...
Revit Version: R2026.4
Hardware: i9 14900K, 64GB, Nvidia RTX 2000 Ada 16GB
Add-ins: ElumTools; Ripple-HVAC; ElectroBIM; Qbitec
emst0004
Already done that, it dosen't help.
HVAC-Novice
Explain exactly what you did. Downloading a file is agnostic to what may already be installed. I have R2025.4 installed and I can download the installation files a million more times without issues. What you may already have installed doesn't become relevant before you execute the installation routine.
Are you properly downloading the files, and then install? Or are you doing one of those web installations or installations out of the update tool? Download all files to a LOCAL drive first, then install.
emst0004
I found a solution, i downloaded the Autodesk Access and then installed 2026.
