import operator preference to foreground
Bench-Mark-5
Observer Observer
Bench-Mark-5
Observer
Observer
in Revit, how do I set preference for CAD links/ imports to insert in foreground as default, and not background?
syman2000
You can't. It is set as background as default. Several users raise up the same issue for over decade and it is still set as background. You can upvote this feature from Revit idea if you want this available in future release.
https://forums.autodesk.com/t5/revit-ideas/add-foreground-background-option-for-all-dwg-linked-files...
ennujozlagam
its better to use link cad in-case there are amendments you can easily reload and set to foreground. thanks
