Import CSV - no points were found in file error
michaelN96YM
Message 1 of 23
michaelN96YM
I've checked all over to find a solution wrt a csv file import to create topography. See atatcehed csv file.
I've tried changing period to comma and neither works.
Keep getting the same issue.
  • CSV
Replies (22)
Message 21 of 23
michaelN96YM
I promise you, it worked using Revit 2023 - do you want me to send you a screen recording? As it seems you do not believe me
Message 22 of 23
No. I'm done with you.
Good luck.
Message 23 of 23
michaelN96YM
I tried a different method.
I used WORD to remove all spaces etc and copied to excel into 1  column.
I then opened te csv file in revit and it worked.
See screen recording: https://drive.google.com/file/d/19aKkylmoZRstis63J4reh2M-Tmpbwryt/view?usp=share_link
