Dimension in 3D Ortho View
12 ANTWORTEN 12
GELÖST
Nachricht 1 von 13
shelmsGYSXD
705 Aufrufe, 12 Antworten
I am trying to create a dimension in a 3d orthographic view that shows the height of this object. Normally I'd activate the view, click on set work plane, click pick a plane, and dimension that way. But because the object is rounded I cant pick the correct plane that allows for the vertical dimension I need. How do i fix this?
12 ANTWORTEN 12
Nachricht 2 von 13
als Antwort auf: shelmsGYSXD
Pick a Plane of something next to it that is not rounded - or temporary create a 3D reference object like a wall or something.  Or am I misunderstanding the challenge?
Nachricht 3 von 13
shelmsGYSXD
als Antwort auf: barthbradley
I made the orthographic view to be put on a sheet. I did this by making my object an assembly and creating an assembly view, so I can't pick something next to it because there is nothing next to it. Hope I am making sense
Nachricht 4 von 13
Well, you Add and Remove elements from an Assembly.
Nachricht 5 von 13
Just to clarify...you are trying to place a vertical dimension like I'm showing here; right?
If so, why don't you just orient the Work Plane to a Grid Line?
Nachricht 6 von 13
shelmsGYSXD
No I included a photo in my question that shows the dimension I'm trying to get. Top to bottom
Nachricht 7 von 13
Like this.  Sure it can be done easily.
- add a ref plane in a plan view and name it
- go to the assembly 3d view and set work plane
- place dim
Nachricht 8 von 13
Orient the Work Plane to a Grid Line then.
Nachricht 9 von 13
shelmsGYSXD
als Antwort auf: ToanDN
This is what I was looking for. I appreciate it
Nachricht 10 von 13
That's exactly the same as using a Grid, except a Grid is less gymnastics.  Just place a Grid. Bada bing!
Nachricht 11 von 13
Nachricht 12 von 13
@barthbradley wrote:
Nachricht 13 von 13
RyanCameron
Very nice. Good idea.
RB Cameron, AIA, LEED AP, EDAC
Digital Practice Leader
