I've checked all over to find a solution wrt a csv file import to create topography. See atatcehed csv file.
I've tried changing period to comma and neither works.
Keep getting the same issue.
Gelöst! Gehe zur Lösung
Gelöst von michaelN96YM. Gehe zur Lösung
Try deleting the 4th column. You only need x,y,z.
...get rid of the semi-colons in the cell values.
The CSV format is all wrong. If you are not sure if the semicolon separating columns or separating decimals then it is better to ask the author to give you a tabulated csv.
This is super weird - see my screen shot of the csv file - does not look like the one you opened.
I've got a pretty good understanding as it is very simple, the csv file i have only has three columns with numeric data.
The column/period is part of the value. I tried using a period and then column.
screenshot 2.png looks correct. Does that one fail as Comma Separated Values? Try saving it as a txt file and using that.
I did expand all the cells, not getting what is showng on your side. I've added the csv file again.
Not sure why it looks like that on your side, on my side it is in three columns
I tried saving it as csv utf-8. See attached images to show you they are in seperate columns
Okay, if it's 3 columns on your end, then use a comma to separate values. On my end (and in that screenshot), I see semicolons.
Yeah, I don't what's going on, but I've downloaded and opened your CSV three times and this is what I get:
If the CSV you posted here is the same CSV you are using in Revit, then there's your problem.
I tried another projects csv - all in one column with extra information (point indicator). see image. And it worked...now i'm super confused
Why don't you save that file as a txt file? Revit can create a Toposurface from txt as well.
Here's what I get. Weird-looking Topo. Look familiar to you?
I copied all the data in the A column to Notepad, replaced all the semicolons with commas, and saved it. Then I used this txt file to create the Topo you see.
@michaelN96YM wrote:I tried another projects csv - all in one column with extra information (point indicator). see image. And it worked...now i'm super confused
You couldn't have created a Toposurface from a CSV formatted that way.
