Import CSV - no points were found in file error
michaelN96YM
Message 1 of 23
michaelN96YM
I've checked all over to find a solution wrt a csv file import to create topography. See atatcehed csv file.
I've tried changing period to comma and neither works.
Keep getting the same issue.
Replies (22)
Message 21 of 23
michaelN96YM
I promise you, it worked using Revit 2023 - do you want me to send you a screen recording? As it seems you do not believe me
Message 22 of 23
No. I'm done with you.
Good luck.
Message 23 of 23
michaelN96YM
I tried a different method.
I used WORD to remove all spaces etc and copied to excel into 1  column.
I then opened te csv file in revit and it worked.
See screen recording: https://drive.google.com/file/d/19aKkylmoZRstis63J4reh2M-Tmpbwryt/view?usp=share_link
