Hi!
I'm creating a IfcExportAs shared parameter (and IfcExportType), and I have some short questions that I appreciate if someone could help me out.
Firstly, I was wondering if I have to set the type of parameter as "text"?
Then, in the Project Parameter section, should I let it be set as "Instance" or "Type"? And what about IfcExportType, should I follow the same procedure, and choose Type instead?
Thanks!
Arghavan
Is it a text value? Then use "Text". Is the text value unique for each instance? Then use "Instance".
Thanks! But I'm not sure if "the text value is unique for each instance".
