door tag problem
door tag problem
bozandilistan
Message 1 of 9
door tag problem
bozandilistan
My door tag showing the dimensions wrong. Door dimensions are 180x210, but it shows as 200x200. But in another project file, same door and same tag, it shows properly. I didn't finy any solution.
Replies (8)
Message 2 of 9
The label in the door tag may read different parameters, not Width and Height.
Message 3 of 9
bozandilistan
but these parameters are  same for the other door too, they are same doors actually. opy and paste.. i didn't get if problem because of door family or tag family or about project file.
Message 4 of 9
Share the door tag family and the door family.
Message 5 of 9
bozandilistan
here is
Message 6 of 9
I found nothing wrong.  Any chance you can share the stripped down project file where the tag reads incorrect values?
Message 7 of 9
In the project that is showing incorrect, make sure the Project Units are set correctly. The values will both show 200 if the Project Units are set to round to the nearest 100.
Message 8 of 9
...so the solution is units and precision? Or, is this still unresolved?
Message 9 of 9
bozandilistan
unresolved..
