Hello
When trying to install the COBie 2018 Revit Extension I receive the following error and the install fails:
"Error writing to file: XLConnector.dll. Verify that you have access to that directory."
Any advice?
Please see the installation guide for the COBie extension HERE
See links to download the installation file depending on your version of Revit.
Regarding the 'verify access to directory' error please try the following for me.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
Viveka CD
Designated Specialist - AEC, AR/VR Research
Autodesk playlists| Find Recommended Hardware| System requirements for Revit products| Contact Autodesk Support| Autodesk Virtual Agent| Browse Revit Ideas| Revit Tips/Tricks| Revit Help| Revit Books
Hi
With my Anti-Virus disabled completely I managed to get a different error (see attached image). I am using Revit 2018.1.
I next tried the install again with Revit closed. This time it asked if I would like to repair COBie Extensions. After the repair the Extensions appear in the Ribbon (Add-Ins).
I have not tested the Extensions yet to see if they work.
Hugh
Hi @Hugh_Compton
I've got same issue with you. But my issue has been solved by
I create folder before setting up these plug-in in the path below
C:\Users\***\AppData\Local\Programs\Autodesk\COBie Extension\2018
When you setup, you will see the path was suggested. You need to change the path to new
The setting up will complete
