IFC wrong rotation
IFC wrong rotation
kirill.niashin.ru
IFC wrong rotation
kirill.niashin.ru
Dear Colleagues,
As i know - the problem is exists in all versions.
When Revit links IFC it make a wrong rotation of it (rotate according project north, not according true norht).
By my opinion it is application misstake.
This happens even with Revitexported  IFC.
I created small test to illustrate it (files are attached):
2 Revit files with shared coordinates and different Angle to True North (wall arrow is orient to True North) and they linkin properly to each other:
 Also i exported them in to IFC (with Project Orign - Current shared coordinates):
Stranges begins when we linking IFC to Revit (blue - is IFC):
 I think this is very critical solution for coordination.
Also in NavisWorks this IFC are linking incorrect if IFC reading set to "Revit IFC".
 If this tik will be uncheck - all is correct.
dli993AM
I am seeing the same behaviour in Revit 2020. I would love to say what version of the IFC exporter I am using but that information has been removed ...
Could we have a response from Autodesk or a few more people confirming this situation?
Maquina_22
hopefully autodesk will fix this problem in a new update for all revit versions.
lryckeboer
Observer
Observer
This issue is still present with Revit/Navisworks 2022. In Navisworks the "Revit IFC" tickbox has been replaced by a "Conversion Method" dropdown though. Changing this value from "modern" to "legacy" is the same as unticking the former checkbox, and I can confirm that fixes the rotation in Navisworks.
