IFC mapping with system families
ivan_guerra
ivan_guerra
Hello, in Revit, mapping between categories and subcategories of Revit with IFC Entities and types can be done via the export table, or via the IfcExportAs and IfcExportType parameters.
With either method, it works perfectly with LOADABLE families, but with system families, you only support one or two IFC entities.
Do you know or do you have a list of the exact behavior of each system category?
For example: Category Walls: only works with IfcWall and also only through table, not parameters.
And so on with all system categories.
Thank you
Si encuentras mi mensaje interesante, dale un "Me gusta"
Si esto resuelve tu problema, por favor haz clic en ACEPTAR COMO SOLUCIÓN para mejorar el Foro.
Iván Guerra - Consultor BIM
Escucha mi podcast sobre BIM: "bimlevel"
en bimlevel.com - itunes - Spotify - Ivoox
arturopolanco
Hi @ivan_guerra
Thanks for share, this info
Arturo Polanco
AEC Solutions Specialist - Civil Infrastructure
Youtube | Twitter
