Sub connection visible in crop view
XXalessio.amodioXX
Message 1 of 8
XXalessio.amodioXX
Hi all,
I am trying to hide sub connection, but even if crop view is activated they are still visible. This cause me miss centering in sheets and annoying big regions in sheets. How come?
Replies (7)
Message 2 of 8
ennujozlagam
it could be your assigned view template? set to none and see if helps. thanks
Message 3 of 8
XXalessio.amodioXX
hi
thanks for reply.
It is not in template, i have tried to enable temporary view properties,not working. The main thing is that objects OUT of crop region with crop view activated should not  be displayed. How come?
Message 4 of 8
What are those elements? I can't read their Properties in video.
But, what about a Scope Box?  Might be worth a try.
Message 5 of 8
Lots of things are still selectable though not visible when the views are cropped.  Try curtain grids for instance.  But that shouldn't be a big deal placing and arranging views on sheets, or printing.
Message 6 of 8
XXalessio.amodioXX
The elements are sub-connection, steel>milter.
Unfortunatelly in VG there is no subconnection visibility on/off. They can be hiddent turnig off ALL structural connection. Not my case
Message 7 of 8
XXalessio.amodioXX
I would not say so. They are really annoying in sheets placement.
Message 8 of 8
zmiller0171
Observer
Observer
This isn't a solution, but just a work around. You can select the Sub-Connections and change the Workset to one that is not visible in the view. Would be nice if it was a little simpler than that though.
