IFC Export with ArchiCAD plug in error
travis.temples
travis.temples
I am trying to export to IFC using the Graphisoft plug in for Revit and this error pops up. It will not let me save the project. I have not used the Revit translator to IFC due to it not working like it should either. Here is the error I receive. Any assistance would be great.
L.Maas
As this error is related to third party add-in you should check out maker (Graphisoft) of that add-in. They should be in a better position to tell you what the issue/solution is.
Louis
Please mention Revit version, especially when uploading Revit files.
