Modify scale to NTS in sheet
2 ANTWORTEN 2
GELÖST
Nachricht 1 von 3
jayartadle
1655 Aufrufe, 2 Antworten
Please help I want to change the scale in my sheet to NTS.
2 ANTWORTEN 2
Nachricht 2 von 3
Karol_Piroska
als Antwort auf: jayartadle
why dont use edit the titleblock, save as copy with NTS instead of scale and use that one?
Nachricht 3 von 3
RDAOU
@jayartadle
  1. Edit the Title Block Family
  2. Give the Scale Label a visibility Y/N Parameter (Call that parameter SCALE)
  3. Add a NTS text label same Place Visibility Y/N Parameter & NTS = not(SCALE)
Reload to project ... on the sheets with No Scale ...Select the TB and check SCALE on  or OFF
