IFC Export-Structural columns missing
11 REPLIES 11
Message 1 of 12
2610 Views, 11 Replies
I have no clue why my Structural columns missing in ifc file?
Checked
Export-Options-ifc options
for structural columns IFC Class name is appearing IfcColumn. Is it IFC Type causing trouble? it was blank I types columns still no columns appearing in IFC file
whats solution?
See the image
11 REPLIES 11
Message 2 of 12
Are they in a linked file?
Message 3 of 12
in reply to: ToanDN
Yes.
I did export to ifc and just to make sure everything appear correct I opened new file and linked in this ifc file that's when I noticed columns missing
Message 4 of 12
No.  What I meant to ask was that if the original structural columns were in a linked Revit file.
Message 5 of 12
in reply to: ToanDN
No, Its not in Linked file.
Message 6 of 12
Viveka_CD
Hi @Anonymous
Can you try this for me?
Link and bind the IFC file in a host model and see if you get the column from the IFC file.
See HERE for more information on Revit and IFC files
If this does not resolve your issue - send us the file and your journal to troubleshoot. I can share a private folder to upload. Let me know if you have any questions.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions.
Thank you.
Message 7 of 12
in reply to: Viveka_CD
Thanks for reply.
Tried bind. Doesn't seem to work.
Temporary solution I found is
I opened Revit 2017 (Original file was in 2016)
Detached from central and upgraded to 2017 then did ifc export
After that columns appeared. (IFC export settings were same in both version for columns)
Happy to share model with Viveka for further investigation.
How to get the Journal ?
Please provide private folder to upload
Message 8 of 12
Viveka_CD
Hi @Anonymous
Glad to hear that you were able to resolve this issue temporarily! Smiley Happy
Here is the information on how to locate your Journal file.
Also, can you confirm if you have the latest updates and hotfixes for your Revit version?
Please check your inbox for the private folder link.
Message 9 of 12
Viveka_CD
Hi @Anonymous
Thanks for uploading your journal and Revit model.
We will investigate the files and let you know.
Message 10 of 12
Viveka_CD
Hi @Anonymous
I wanted to share an update with you regarding this issue.
I've tested the file and it's working for me, I just wanted to verify. The columns are in place.
  • I tried the IFC export with version 16.6.0 and wanted to check with you if you have the same version installed on your machine.
  • You can download this from the app store.
  • The .NET code used by the Revit 2015-2018 family of products to support IFC can be downloaded HERE
  • From your journal, your Revit build number is 20160217_1800(x64) and you need to install the latest updates for Revit 2016 - see HERE for the latest updates.
Let me know if the above recommendations resolve your issue. if you still continue to face the issue - please send a screenshot of the IFC Export settings.
If you find posts have solved your problem, please click on 'Accept as solution' to help others with similar questions. Kudos welcome!
Thank you.
Message 11 of 12
Thanks for your help Viveka.
My Ifc export version is 16.2.0.0
I will follow your instructions and give a try again
meanwhile, I need to contact our system administrator IT team to get new ifc version installed
As we don't have rights to install
Message 12 of 12
Viveka_CD
Hi @Anonymous
Sure, let me know!
Looking forward to your update.
