Hello, I am trying to export a model to IFC, but when I open the IFC fyle I see that some walls exports as IfcWall but others exports as IfcWallstandardCase, in the mapping I have configurated as IfcWall. Futhermore, I have tried to change it with the parameter IfcExportAs but it does nothing, and also if I specify the IfcExportType paremeter doesn't modify it either.
Thanks for the help
Solved by Lance.Coffey. Go to Solution.
Have you tried use the IFC exporter from the Autodesk App Store?
Thank you for the question @Anonymous!
I’m seeing a similar thread on this topic here: Changing IFC class for system families
In the thread above, it looks like the value was being controlled by the IFC Version that was being exported:
2x3 Coordination View 2.0 -> IfcWallstandardCase
IFC4 Reference View -> IfcWall
In my testing (with a new sample model - attached) I am seeing similar results.
If this doesn’t work for you, could you reply with a sample model for further testing?
Hello, thank you for answering.
In my case in the version 2x3 I have some walls as IfcWall an others as IfcWallStandarCase, if I export in the version 4 all the walls are IfcWall. But I have to export it in 2x3 and I need all the walls as IfcWall, and if it's not possible I would like to undestand why some walls exports as IfcWall and others don't.
I found the following definition from Building Smart for IFCWall with IFC2x3, that may answer why some of these walls are exporting differently:
IfcWallStandardCase used for all occurrences of walls, that have a non-changing thickness along the wall path and where the thickness parameter can be fully described by a material layer set. These walls are always represented geometrically by a SweptSolid geometry, if a 3D geometric representation is assigned,
IfcWall used for all other occurrences of wall, particularly for walls with changing thickness along the wall path (e.g. polygonal walls), or walls with a non-rectangular cross sections (e.g. L-shaped retaining walls).
Looking at the provided sample model, I’m seeing that 11 of the walls are exporting as IfcWallStandardCase, and two are exporting as IfcWall.
Here is a screenshot showing two of these walls:
From what I’m seeing, in the example above the floor cutting into the wall on the right, is causing that wall to have a sufficiently varying thickness to be output as the non-standard IfcWall (removing that floor then re-exporting changes the output so that both walls are output as IfcWallStandardCase.
